95 gmc sierra - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2011, 10:43 PM
95 gmc sierra
i have a 95 gmc sierra short bed 4x4 with 5.3 or 5.7 engine need to know what transmission is the one i need. the shell on mine broke in half
Old 01-08-2011, 09:25 AM
Crosley's Avatar
Wiki Edits: 1659
You need to know what engine you have. The truck should not have a 5.3 LS series engine, unless a person installed that and removed the OE engine
You will need a 1995 or 1996 trans 4L60E 4x4 trans for a direct bolt in replacement. the 1995 - 1996 units have a early PWM lock up design.
1997 trans will work with a solenoid change of the 3-2 solenoid to the proper ohm rate for the 1995 trans.
If the trans case broke, I would suggest looking for a cause. Often bad mounts are a cause
Old 01-08-2011, 12:28 PM
Wiki Edits: 31
I have heard of transmission crossmembers rusting out on those trucks... I'd scout a donor in a junkyard and take the crossmember and all.. even the carrier bearing crossmember if you have a carrier bearing
89 Sierra 350 TBI Honky_pride_2001 Engine 2 02-16-2010 02:59 PM
72' sbc 350 going in a 92 GMC sierra njones308 Hotrodding Basics 2 02-06-2009 05:30 AM
94 gmc sierra spydi Transmission - Rearend 3 12-05-2007 05:14 PM
BBC In a GMC Sierra - will it fit? 69ChevelleAddict Engine 4 07-09-2006 08:44 PM
