95 lumina brake lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2008, 09:40 PM
when I step on the brake the lights don't come on. If I turn the left turn signal on right brake light comes on. Turn the right turn signal on and left brake light comes on
Old 06-22-2008, 08:55 AM
Wiki Edits: 31
check your fuses, sombody may have pranked you... on some fuse blocks, you can jump circuits by putting the fuses in 1 slot over and it makes all kinds of weird stuff happen. This is especially true with most newer Dodge/ Chrysler/ Jeep cars, but some GM's can do it the same.
Old 06-22-2008, 10:46 AM
T-bucket23's Avatar
Wiki Edits: 26
You most likely have a bad turn signal switch or a bad brake light switch. If the wrong side signal is comming on it is most likely the turn signal switch.
Do you have to be stepping on the brake for the wrong light to come on.
Chet
Brake lights 1966bowtie Electrical 4 08-11-2007 12:09 AM
58 Chevy Apache : Brake Lights / Wiring Harness Rathimis Electrical 3 12-13-2005 09:34 AM
76 firebird with no brake lights SassyWinds Electrical 2 01-26-2005 02:22 AM
Brake light/turn signal lights wont work together ChevyForever Electrical 1 10-04-2004 02:19 PM
Ranger Brake Lights nova69 Electrical 2 09-02-2004 12:50 AM
