'95 Roadmaster Donor for '37 Roadmaster - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2012, 11:08 AM
Mutt's37Buick's Avatar
Got to tell everyone I'm pretty stoked. After lots of research and searching I finally bought a donor car for my '37 Buick Roadmaster.
I bought a '95 Roadmaster with a LT1 engine, 4L60E transmission, Impala SS wheels, and only 52K miles.
I'm not planning on using the rear drive because I already have '97 Tbird irs.
I am planning on using the engine, transmission, steering column, wheels, leather heated seats (with some mods), instrument cluster, electrical harness.
1) Does anyone know if I can use the:
electric windows,
power locks,
door hinges,
air ride system on my t-bird irs,
floor to replace wood floor in my '37,
and AC & heating systems?
Thanks
Old 03-09-2012, 11:29 AM
lt1silverhawk's Avatar
"But how do it know?"
Last wiki edit: How to rebuild a Rochester Quadrajet 4MV carbureto... Last photo:
Wiki Edits: 132
You lucky! I've always wanted one of those. What condition is it in?
Old 03-09-2012, 11:39 AM
I inherited the '37. It is all complete, but sat outside for 25 years so rust repair req'd. Has not ran since 50's. The '95 Roadmaster donor car is in excellent condition. Will part out anthing I don't use.
Thanks
Old 03-09-2012, 06:10 PM
techinspector1's Avatar
Wiki Edits: 326
Don't sell or throw away any pieces off the '95 until the entire project is done. I speak from experience.
Old 03-09-2012, 10:49 PM
Thanks for the advice
Old 03-12-2012, 09:47 AM
Swapping floor
One hot rod builder said that the trans hump of the '95 Roadmaster floor may not be tall enough in my '37, just depends on where the engine and trans sit.
He said if it is not tall enough I can build a custom hump.
1) If the hump is not tall enough, is it still worthwhile to cut out the donor floor?
2) The metal on the newer car is probably thinner than my '37 Buick. Is it thick enough or would I be better off with thicker metal.
3) Are the replacement panels that can be bought a lot easier to install and can anyone recommend a good source if I go that route?
Thanks
Can i put roadmaster int in 95 caprice Seanj Interior 4 12-14-2009 11:39 AM
Buick Roadmaster stanray Introduce Yourself 2 02-06-2007 07:06 AM
48 Roadmaster beecherdoris General Rodding Tech 1 12-20-2006 03:38 PM
buick roadmaster Ace_Spades307 Engine 3 11-26-2005 10:52 PM
53 buick roadmaster ???? axle bastard Hotrodders' Lounge 6 09-12-2002 08:19 AM
