95 ss impala 4l60e tranny problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2009, 11:14 AM
just built a 4l60e tranny for a 95 ss impala , all was fine for 70 miles and the engine overheated and son after the tranny started to slip in 1st and began to shift sloppy I heard a ticking noise and smelled burnt fluid
Old 01-17-2009, 05:13 PM
tnsmith10's Avatar
when will it rain???
ok, well, the info you gave is limited, but ill ask some questions to try and help narrow it down... here goes, is this your 1st 4L60E rebuild?
before installation, did you flush out the cooler lines?
did you find the root cause of failure on why the trans failed in the first place?
did you scan for codes before removal to see if it had any electrical problems?
more info on details can help us help[ you find out what happened and whats going on with it now...
and last question, did you buy a new/reman torque converter?
Old 01-18-2009, 10:20 AM
help 4l60e
Yes, new torque conv, yes cleaned and flushed lines, no codes stored * has obd1 and this is my 4th 4l60e the failure was a broken accumulator, we plugged it off and added a trans go plate and it was awesome for 80 miles. thank you so much for the questions and I so much hope you can help me figure this thing out, Ken
Old 01-18-2009, 12:43 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
These engines (and transmissions) rely on electric fans. There is a known problem on 1994-96 'B-body' cars (Caprice, Impala, Roadmaster). The culprit is the primary cooling fan relay- it overheats and fails, thus, no fan to cool anything.
Make sure your fan and relay is OK. The ticking is probably your overheating engine.
GM sells a service package under part # 12167644
A pressure check on the trans will help in diagnosis.
"Dollars are like votes, except that they actually count."
99 GMC Sonoma, 2.2L 4L60E problems mkhurley Transmission - Rearend 4 12-20-2008 05:53 PM
GM 4L60E Problems GMkid43 Transmission - Rearend 15 08-25-2008 09:31 AM
Simple 62 Impala SS wiring question ddove1972 Electrical 1 10-26-2007 05:35 AM
Can U Tell Me IF This Is A REAL IMPALA SS?? syclone477 General Rodding Tech 6 11-24-2005 05:07 AM
88 AOD tranny problems rflud Transmission - Rearend 9 02-17-2003 05:53 PM
