Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 95 tbi problems! will not run!
Old 12-09-2012, 09:09 AM
LATECH's Avatar
LATECH LATECH is offline
Last journal entry: GTO Reproduction Hood
Also, on a chevy, rather than wrestle with removing rusty tank straps, I remove the BED. It has 8 bolts , easy to remove, then the rear harness and ground lead back at the bumper, and the filler shroud at the side body panel. Get 3 friends to help lift it off. Leaves it wide open. Better than laying under a truck, eating dirt, rust and ultimately lifting 250 lbs of sloshing fuel in a tank
Fact is stranger than Fiction
