Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 95 tbi problems! will not run!
Old 12-09-2012, 12:49 PM
V8&4spd V8&4spd is offline
Last journal entry: Paint
There is a small fuel line on the end of the fuel pump inside the gas tank. You might want to double check that. I had one swell up on me and there was a split in it that you could not see at first. I think the junk gas they sell now had something to do with it. If you drop the gas tank you might as well change the fuel pump while you are in there. That small rubber fuel line caused me all kinds of work.
