95 YJ rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2009, 10:18 AM
95 YJ rearend
I have a jeep with 33 1/2 tires with a 3 inch lift the gears were mangled when i bought it . My question is the original rearend is 4.10 can i go with another gear ratio to optimize proformance in a 4 cylinder but still be able to play in the mud holes.
Old 01-23-2009, 11:23 AM
You can change the gears to a 4:56 or even a 4:88,but you will also need to change the gears in the front differential to mach the rear.
The YJ's came with a dana 30 front axle and a dana 35 rear axle.
Old 01-24-2009, 11:53 AM
Thanks
I am such a girl... Thanks for the advice.
Welding Rearend 23 T General Rodding Tech 26 04-21-2008 07:49 PM
95 Chevrolet rearend in an 86 Chevrolet? kvsbmsdws Transmission - Rearend 1 01-03-2008 01:11 PM
I need some input on putting a Ford rearend under a 1972 Dodge Dart onebadmerc Transmission - Rearend 7 12-21-2005 11:30 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 07:23 PM
rearend for a Model A 30coupe Transmission - Rearend 10 11-25-2002 09:04 PM
