96 454 compression - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2010, 08:16 PM
96 454 compression
i have a 96 vortec 454 stock flat top pistons 2 valve relief and i am thinking the compression is 8.75.1 not for sure. My question is if i was to take off the vortec heads which is 100cc use an older set casting 3904390 ported and bowel work with big valves have them shaved 025" will it be possible to get 9.5.1 or higher
Old 09-08-2010, 09:19 PM
techinspector1's Avatar
Wiki Edits: 326
I'm thinking the spec on the 390 chambers is 98 and change, so what are you expecting gain by replacing 1996 technology with 1967 technology? Are you trying to gain some cr so you can use more cam?
I personally have not dealt with a '96 454 Vortec motor, so I don't know if the earlier heads will bolt to the block and seal all the water passages or not. Someone else will be along who has experience with them.
Old 09-09-2010, 12:46 AM
yes i am wanting more cam
96 camaro with 454 RPM General Rodding Tech 6 12-26-2007 05:34 AM
454 Compression Ratio JIMR122783 Engine 1 09-20-2007 04:41 PM
454 Compression Test Results - Help leejoy Engine 1 05-16-2007 09:51 PM
Compression question for the Pro engine builders.. Axelrod Engine 14 01-16-2007 11:29 AM
How to figure compression ratio...... classic_chevy_guy Engine 9 07-26-2005 10:59 PM
