96 4l60e - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2012, 11:51 PM
96 4l60e
i just got a 96 sonoma 4.3l vortec v6 it has a 4l60e trans with some problems.
Their is no reverse at all dont act like it wants to pull or anything. It pulls real good in 1,2,d,od but when shifting from 1st to 2nd it dont shift till you let off the gas alittle thin it shifts.
What i want to know is their any sensor that will couse these problems or is it just time for a rebuild.
Old 09-02-2012, 02:04 AM
just had a similiar problem with my 4l60e the reverse silaniod on the throttle body is either stuck or needs replaced at least thats what it was with mine.
Old 09-02-2012, 02:17 AM
SSedan64's Avatar
^^ Maybe Reverse Solenoid on the Valvebody.
Try doing a search on this site for more Info
Old 09-02-2012, 10:20 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
there is no reverse solenoid in the 4L60e. It is controlled by the manual valve that is moved via the shift linkage.
Mileage on the trans ? If known. Since you just acquired this vehicle the service history may b a mystery
Since you mention all forward gears function... If you place the shifter into manual 1 , drive forward to about 20 mph, the shift to manual 2 . Please note the shift to 2nd gear is proper or not, reply back here.
Please note that over drive does function properly too.
I ask these questions because I have seen vehicle owners that said all forward gears operate and they do not. Then we find the sun shell broken, which will cause a no reverse, no 2nd gear, no over drive
Old 09-02-2012, 11:35 AM
I didnt go into each gear i just go Over Drive i will have to check each gear.
Their is 186,000 miles on the trans i do not know if its the right milage.
Old 09-02-2012, 05:45 PM
1st work 2nd works drive works and over drive works. You do have to let off the gas for it to shift but when you put it into reverse nothing at all acts like its in neutral.
4l60e matthewross Transmission - Rearend 1 01-10-2012 11:07 AM
2000 4L60E to an earlier 4L60E, What do I need to change out aquaterrarv Transmission - Rearend 2 04-08-2010 07:22 PM
4l60e no OD or D jbroome2 Transmission - Rearend 4 03-07-2010 11:35 AM
4l60e butters Transmission - Rearend 4 11-09-2008 12:40 PM
4l60e help trevorbg Introduce Yourself 1 12-23-2007 06:32 AM
