96 blazer 4.3 swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2008, 12:53 PM
96 blazer 4.3 swap
I have a 96 blazer 4x4 with a knocking rod, automatic trans I believe a 4l60.
I just got a totaled 98 Blzer 4x4. I was plannig on useing the 98 long block with all of the 96 acc. and injection. Will this work? I read on another forum that one has the bell haousing cast in with the trans and one has a seperat bell housing, are they interchangable?
Mike
Old 11-27-2008, 01:01 PM
3rdmember
the bellhousing is NOT part of the engine so that won't be a problem.
if they're both the vortec engine, i don't see a problem BUT if you're buddies with somebody (like a salvage yard) with a hollander interchange book, i'd check 1st...
slip 'em 10 bucks for doing it, it'll be worth it in the long run.
Old 11-29-2008, 06:35 PM
There is a differnce in the trasmissions. I am running a 1999 bolt on 360 bellhousing on my 97 truck that originally had the 1 piece, sheetmetal TC cover.
these differences wont affect your swap at all. the 1996-2000 V6 and V8's are all the same.
This is 100% correct.
peace
Hog
Cam swap Questions wayfast77 Engine 3 10-18-2006 04:52 AM
4.3v6 swap for chev 350sb? boneyard Buick Engine 3 09-03-2006 12:26 PM
S10 700R4 to 76 Blazer swap Drewnashty Transmission - Rearend 6 06-12-2006 09:30 PM
engine swap in a s10 blazer bill bennett Introduce Yourself 4 05-12-2006 10:47 PM
2.8 to 4.3 swap Gassman Engine 2 09-11-2003 09:24 PM
