96 blazer hesitation problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2006, 09:32 PM
I have a 96 blazer with a 4.3 engine. The vehicle runs fine till i shut it off for a bit when i get back into it to leave it has a hesitation in the engine as i try to get back up to speed it takes like 10 seconds for it to catch then once its up too speed its fine again. I changed the fuel filter and it actually seems worse now. Only after its been shut off then restarted and it seems as i'm turning a corner it happens. Does this sound like the fuel pump is going i would just like to get some input before changing it. I'm sure its a fuel problem. Thanks
Old 11-07-2006, 10:02 PM
driveability's Avatar
Last journal entry: 930 4 speed transmission
It's a 96 and likely has CPI as a fuel system, the units have a funny way of leaking fuel into the intake/engine. I would look close at the fuel systems pressure and its ability to hold pressure after shut down. It should hold pressure after shut down and or not just drop off. If it does drop off I would be looking for the reason.
John
96 Blazer Overhead Console Temperature Indication 454impala69 Electrical 13 03-25-2010 11:21 AM
89 Suburban 700R4 Problem JoeB Transmission - Rearend 13 11-06-2006 03:56 PM
96 chevy silverado taillight problem? machmn Electrical 5 09-22-2004 02:02 PM
96 chevy s10 blazer turboed quick jesshwarren Engine 2 11-28-2003 03:15 PM
Fuel / Carb problem DoubleVision Engine 5 10-28-2002 05:18 PM
