This site gives the measurements of the 396. Don't show the 3.8 or tell you if they will fit. You will need to measure for yourself.
http://carnut.com/specs/engdim.html Aaron |
If you do this swap be sure to put an 8 point cage in the car so it won't blow out the rear window every time you stand on the gas......lol.
HMMMM it is a convertible.......had a 66 nova with a 454 ls6 in it, it made the doors not want to close good. |
I've worked on these cars with the 350 in them and they suck. My '95 Corvette is much easier to work on than F-bodies of the same era. I can't imagine putting a big block in that Camaro without a lot of changes to the chassis and underhood areas to make it hold up and to provide adequate room. In short, I'd build it as a pro street car if I were going to do it.
96 camaro with 454
What does it take to put a 5.7 V8 into the 6 cylinder 96 Camaro let alone a big block? How about mounts and such? Thanks. W
| Recent General Rodding Tech posts with photos |
| 86 camaro with a 454 in it | 77formula | Suspension - Brakes - Steering | 2 | 04-02-2007 07:23 AM |
| The Camaro Guy | ZedLepplin | Introduce Yourself | 1 | 03-08-2007 05:55 AM |
| elect fan help 96 camaro | kiaserknife | Engine | 0 | 11-10-2003 05:02 PM |
| 96 Camaro Battery problem... | shysteeboi | Electrical | 5 | 10-02-2003 08:31 PM |
| 454 in an 84 camaro | HORTON | Engine | 10 | 10-09-2002 10:35 PM |
