96 Camaro with 4L60E, will 350 chevy engine bolt up - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-19-2012, 02:25 PM
I just got a 96 camaro rs shell for free and straight body I got a I believe a 4l60 tranny with it is there a way I can use this transmission with a 350 first gen motor and. Do I need to run the controller box if I can
Old 12-19-2012, 03:16 PM
If it was originally a V8 car, the engine bolts up. If it was a V6 car, it won't. If it's a 4L60E (as opposed to a 4L60), it doesn't shift without a computer.
Old 12-19-2012, 06:03 PM
Ok Its a v6. So ill Have to Fine a tranny do u know how much work till be to get the 350 first gen to fit in the car
Old 12-19-2012, 06:33 PM
Getting a 350 engine in that car is going to be a bugger. The only 2 ways that I've been successful in getting them in is pulling the entire front clip off or removing the frame support & installing the engine from the bottom. Reason being, the engine firewall sits further back than the windshield which prevents the engine from being installed from the top. Good Luck!!!
Old 12-19-2012, 06:35 PM
Banned
they came with lt1 genII a gen one with a carb you'll hit the cowl..
tpi should fit.. but a carb you'll be hard pressed to get an air cleaner on it..
Old 12-19-2012, 06:43 PM
Ok What do u suggest to get it to fit
Old 12-19-2012, 06:52 PM
These cars came with V8's so there is room. A '96 is a computer controlled engine, so you have to decide if you want a computer, or a carb engine. Buying another V6 would be the easiest thing to do, but that's probably not what you're looking for. After market wiring harness and motor mounts are available for the 5.7L.
If you go with a V8, you'll need a new Trany as well and possibly a cross member. Maybe a new radiator. Motor mount and cross member holes should already be there, so factory mounts should do.
Easiest V8 conversion, IMHO is to go the carb route and a hood scoop. Then maybe a manual trany.
As far as how much work, I'd say a lot of work to make it a V8 car, but that's subjective..... How badly do you want a V8?
Old 12-19-2012, 06:55 PM
Banned
here is a photo of the lt1 efi, see how low that set up is, and see cowl.. I'm willing to bet a g.m. factory 1985 carb intake thats mighty short to clear the 3rd gen hoods, you'll not get a carb on it. and if you did the airhorn would be touching the cowl.. if it even slides into place..
Old 12-19-2012, 07:09 PM
Ok so I would Have to put a cowl iduction Good then right and how Howard is it to put the engin threw the bottom with out a lift
Old 12-19-2012, 07:19 PM
Old 12-19-2012, 07:31 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
What are you going to do about the distributor when you get that thing in there? Better cut a hole in the dash now so you can adjust your timing and change plug wires...
Old 12-19-2012, 07:59 PM
So u have to cut a hole in dash is there any way around it
Old 12-19-2012, 08:06 PM
Wiki Edits: 15
I was just joking more or less about cutting the hole, but you're going to be hard-pressed to do any adjustments or tune up work with it buried under the cowl back there. Mines a pain in the butt as it is, and it's in a fullsize truck with a ton of room. Are you married to the idea of putting a gen I sbc in it? An LT1 would be cheap, a 5.3L would be cheaper. Both would avoid your distributor problem.
Old 12-19-2012, 08:08 PM
I probably would be ok with going le1 but ive got sbc Hwre thats already built and im short on Cash that way
Old 12-19-2012, 08:12 PM
Banned
yup.. run a lt1 gen 2 or an ls
the glass covers half the engine..
Engine bolt sizes for 350 chevy eric32 Engine 6 05-02-2009 09:05 PM
2 bolt 400 or 4 bolt 350 chevy chevy350cutlass Engine 19 10-30-2008 09:42 AM
chevy camaro vs chevy pickup bolt pattern old fords Transmission - Rearend 2 09-19-2008 07:07 PM
engine cooling specs for 350 4 bolt chevy downunder Introduce Yourself 2 10-02-2004 11:41 PM
9 bolt chevy camaro rearend jrtraveler79 Transmission - Rearend 2 03-21-2004 12:12 PM
