96 Chev 2500 Tranmission? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2012, 07:36 PM
Just purchased a 96 Chev Pick Up 2500 with a 5.7 4 x 4 for a runaround truck (right after my son totaled my 01 2500 HD in purchased new) anyway. When I purchased it I checked the trany fluid and it was very clean and no clutch smell. After driving is a bit, two things seemed to happen, would not shift out of 1st gear and the speedometer would stop working. If you ran it or shut it down it would start working again. Now when I step on the brakes, the speedometer and tach, go up and down. Is this electrical or mechanical?? An Help would be greatly appreciated. Yes did a lot of racing in the 60's THANKS C. Richard
Old 08-24-2012, 02:51 AM
SSedan64's Avatar
Will be a 4L60E Trans E=Electronic controlled.
It does sound like an electrical problem. If the Speedo doesn't work on these they wont shift. I'd check all the electrical connections 1st. They're also known to have problems when the Ignition switch gets worn.
Old 08-24-2012, 11:36 AM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
Unless it's a 5.0 or 4.3 LD, it should be a 4L80E in the 2500, right?
Old 08-28-2012, 01:31 AM
SSedan64's Avatar
I missed the 2500. Probably is a 4L80E.
best tranmission for my soon to be town cruiser jds87s10 General Rodding Tech 1 07-03-2011 07:47 PM
Tranmission Engine merge professor229 Transmission - Rearend 0 05-22-2011 07:39 AM
tranmission swap m2summit Transmission - Rearend 3 03-07-2008 06:03 PM
94+ Chev 2500 5-spd Bryan59EC Transmission - Rearend 0 08-11-2006 07:56 PM
chev 2500 series convert to 8 bolt John Tyrer Suspension - Brakes - Steering 2 08-22-2005 03:01 PM
