Start a wiki article on any hotrodding subject:
Then, others help to build it.
Read and write hotrodding articles in the Crankshaft Coalition Wiki.
See 150+ articles, or read The 8-sentence guide.
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 11-13-2002, 05:37 PM
badriand's Avatar
badriand badriand is offline
Question 96 chevy 305 vortec heads on 350 block
I have a 96 chevy pickup with a 305 vortec engine which has about 200,000 miles on it. I was wanting to put a 350 vortec block bored .30 over in it and I was wondering if my stock 305 heads would work or do I need to but a set of 350 heads. Also does anyone know if I can use my 305 intake on the 350 block? Any help would be appreciated. Thanks
Old 11-13-2002, 05:59 PM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Post
you can use the 305 heads on the 350 block but you will increase compression as the 305 heads have a smaller comb. chamber, intake will fit also. if you are going to build the 350 from scratch with a new bore job,pistons are available for 305 heads on a 350, the rebuilders can't find good 350 cores(they are usually cracked) so the piston companies are making pistons for your combo in all oversizes.
Old 11-13-2002, 06:18 PM
badriand's Avatar
Post
Thanks, should I go with 350 heads due to the increased compression, or will it be ok.
Old 11-13-2002, 06:23 PM
Post
you can use the 305's just be careful about spark knock, use good gas when makin the old truck work.
Old 11-13-2002, 06:29 PM
badriand's Avatar
Post
Thanks again for replying, this is a everyday work truck for me, so I probably should be on the safe side and go with the 350 heads huh.
Thanks
Old 02-19-2006, 08:10 PM
rhibbsiii rhibbsiii is offline
I am learning as I go. I think the 305 heads sound good. I have a question though. What do you mean about "spark knock"
Old 02-20-2006, 06:45 AM
matt167 matt167 is offline
matt167's barnstarLast wiki edit: Choices: 327 with factory oversized valves or 350?
Wiki Edits: 23
pre ignition/ detonation, fuel mixture ignites before it is supposto, you get it real bad and your cleaning pistion material off the spark plugs.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
