Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 96 chevy 4l60e
Thread: 96 chevy 4l60e
Old 01-13-2013, 07:47 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Not sure I understand the problem.
IF you are talking about placing the shifter in manual 2nd gear with vehicle at a full stop.... then drive off. The GM design is the 4L60E is in 2nd gear when shifter is in manual 2nd gear position.
The trans will not take off from a full stop in first (1st) gear, then shift to 2nd while the shifter is in manual 2nd gear position
The Following User Says Thank You to Crosley For This Useful Post:
chevy327 (01-13-2013)
