96 Chevy S10 Tail lights are out... - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2011, 03:41 PM
Hey everyone. I have a 96 S10 5 speed manual. The tail lights went out on me last night on my way home from work (causing me to get pulled over.) My break lights work, turn signals work, and my hazard lights work. So what's up with my tail lights??? Thanks for any help
Old 04-25-2011, 04:13 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Probably a blown fuse or a broken ground somewhere.JMO
Cole
Old 04-25-2011, 05:03 PM
Try the simple checks first. There should be dual filament bulbs, and you may have burned out the running lamp on both sides. All the items that work (brakes, turn and hazard) use the bright filament in the bulb; running lamps use the low output filament in the bulb.
Sometimes the bulb on one side burns out first, but you don't notice it. Then when the 2nd one goes out it seems likes both quit at one time. If you have a four wire trailer connector, you can also use a multimeter to verify there is power getting to the rear lights.
If its not the bulb, then its probably the wire that runs to the tail lamps.
Bruce
Old 04-25-2011, 06:30 PM
X2
Are your side marker lights still working? If so it's probably just the bulbs burnt out. I believe they are on the same fuse. Only other thing it might be is the wire to the tail lights.
tail lights and dash lights quit ashman Electrical 5 08-30-2010 12:27 AM
chevy pickup tail lights frank88chevy Electrical 3 01-23-2008 11:29 AM
79 TA: dash lights and tail lights fuse keeps blowing Gladis Electrical 6 12-01-2007 12:43 AM
voltage to tail lights vs brake lights? stratt134 Electrical 12 06-10-2006 06:51 PM
1954 Chevy Pickup - Tail Lights horvath Electrical 6 02-25-2003 06:04 PM
