Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - '96 Chevy Truck - no low beams
Old 02-11-2005, 02:35 AM
56Thunder's Avatar
56Thunder 56Thunder is offline
Hello all - OK here's my problem. I was driving the other night and smelt something shorting out. I turned on the brights and pulled over to check under the dash and under the hood. Everything looked OK and the smell went away. However, when I pulled away and went to turn my brights off, I had no headlights. So now I can have the brights on or nothing - this is when I pull the blinker switch back and forth from dims to high and with the light switch turned all the way (all of my blinker lights will stay on.) My low beams will come on only when I have the light switch turned half way - set for the running lights. I hope it is something simple, a switch or something that is repacable, but I'm just not sure where to begin. Thanks for any help or advice - sorting through this electric stuff stinks.
Robby
