'96 Eldorado--disarming running lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2006, 01:07 AM
Anybody know how to disarm the daytime running lights on a '96 Cadillac Eldorado?
Old 08-17-2006, 06:06 AM
ElegantInventor's Avatar
Cubic Inches is King
Last journal entry: High Resolution Drawings
Jimfulco,
Under the hood there is a fuse and relay box. Inside the lid of the box is a diagram of the relays, and one is labeled DRL for Daytime Running Lights. Sometimes GM labels this a type of headlight relay.
When the DRL's are on, the relay in question connects the high beam filaments together in series, delivering 6 volts per bulb. When you turn the headlights on, the DRL relay is shut off.
If you simply remove this relay you will have no high beams. All bad.
Now VERIFY which relay is the DRL. Crank the car and release the emergency brake - which will inhibit the DRL's (on a Caddy you probably rarely use the emergency brakes anyway). With the DRL's on, pull the relay, make sure the headlights go out.
If your Caddy will do that, the fix is simple.
Look at the relay. Figure out which terminals are for the COIL. Post a reply here if you are not sure.
Take a pair of side cutters and clip off either one of the two COIL connections to the relay. Put the relay back in. Now the headlights work normally but not the DRL's.
Jon P
Old 08-18-2006, 01:59 AM
I lucked out. This car had a DRL fuse hidden in there, so I pulled it out & the evil DRL's are gone. Thanks.
GM courtesy lights 78 monte Electrical 13 11-25-2009 05:48 PM
96 MonteCarlo No brake lights Ronald Bredeweg Electrical 4 11-12-2003 12:05 PM
Wiring Tail Lights & Turn Signals horvath Electrical 15 04-30-2003 05:04 AM
Back Up Lights - how to choose? horvath Body - Exterior 6 03-04-2003 03:20 PM
my newborn crapped his die-dees: l.e.d lights all blew up bullheimer Electrical 4 08-16-2002 08:44 AM
