96 LT1 in a 38 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 07-02-2012, 06:50 PM
What can i loose on this engine without hurting performance I have a 700R trans. Will be using block hugger headers. I have a painless engine harness.
Old 07-02-2012, 07:11 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
well what harness do you have (Part Number)
you will need a 4l60E trans if you are going to use the stock ECM.
Fact is stranger than Fiction
Old 07-03-2012, 02:04 PM
Thanks for the info.my harness is a 60505 long, it is a painless , what can you tell me about ecm i do not know what car it came out of? engine was buit for corvevtte specs. was buit for a 67 4x4 prodject went south price was right.
Old 07-03-2012, 04:24 PM
LATECH's Avatar
The painless website has all that info. Its says 92-97 LT1 from camaro, firebird, impala,corvette,roadmaster,and caprice.
I would opt to get a used PCM from the Camaro or firebird , or the corvette .
700 bucks for a wiring harness is pretty salty. Maybe I should start building a few.
PCM part numbers were as follows: 16188051, or 88961150.
You need a 4L60E to run with that engine, or the harness and PCM you have wont work. It will go into default mode with out a trans to supply feed back, IE: speed sensor, shift solenoids circuit,pressure regulator solenoid circuit.
Dont open that harness unless you absolutley sure your gonna run it.
I did not see anything for an LT1 to operate on a stand alone basis.
( in other words... without being accompanied by the 4L60E)
If I were you I would round up a 4L60E and run it .The difference in performance and street manners over the 700 r is huge, and the 4L60E is tunable electronically. You wont spill a drop of tranny fluid.
The Following User Says Thank You to LATECH For This Useful Post:
gary38 (07-03-2012)
Recent Modern Electronic Engines posts with photos
LT1 in a 47 chevy? eheine20 Engine 24 12-14-2014 08:23 AM
LT1 Carb Chevy Truck wdunkin Introduce Yourself 2 03-04-2011 03:25 PM
LT1 intake tubing in 36 Chevy jbinwa Engine 1 08-09-2006 10:27 AM
1989 Chevy Corvette LT1 Smraf666 Introduce Yourself 4 11-30-2005 10:00 AM
Stock Chevy 350 LT1 in a 50 Chevy PU bthaxton Hotrodders' Lounge 1 06-30-2002 08:05 PM
