#1
96 mazda 626
mazda 626 2.5l dohc v6 im driving home the other dat car running good thin it starts running like it needs a tune up stumbling with a miss. i did a tune up plugs wires nothing checked the injestors all have gas everything is like it should be but still missing like a POS. i was told i could have a burnt valve but i was also told it wouldnt start out of the blue driving like that it would happen gradually. i would love some help on this problem i dont know what to do and dont realy want to do a valve job on this car.
Register now (free) or login to remove ads |
#2
How many miles on it? Has it had timing belts replaced? Were the spark plug holes full of oil? Bogie |
#5
it was flashing misfire in cylinder 4 after the tune up everything got worse car is now flooding out wont start half the time miss like crazy and shooting a ton of gas or water out the exhaust
#8
Way overdue for cam belts, they are like an every 60-80 thousand mile item with this engine. Bogie |
#10
Distributor cap will cause 1 cylinder not to fire. They break internally. I would also double check your firing order, it is easy to make a mistake. Also look at the inside of the cap for oil, if the seal in the distributor has gone bad it will leak oil into the cap and cause all sorts of issues.
Artificial Intelligence is no match for Natural Stupidity Chet |
#12
I've got a 93 MX-6 with a 2.5. If this is the same motor, it might have a bad distributor. They have the cam sensor, ignition module and coil all built into the disty. It's a common problem with them.
#13
It is very similar to the Honda setups. The cap and oil seals are real common issues
#14
well compression is fine all about the same about 5 off of each other firing order is right cap and button are fine i guess im going to check fuel relay and pump becouse it looks like it isnt getting fuel now mazda should have bought a chevy
| Thread Tools | Search this Thread |
| Similar Threads for: "96 mazda 626" | ||||
| 88 mazda RX7 | jum | Electrical | 2 | 05-25-2007 02:15 AM |
| chevy to mazda | normffff | Engine | 2 | 02-01-2007 12:36 PM |
| 86' mazda | coopusmc | Introduce Yourself | 7 | 08-18-2006 03:14 PM |
| Mazda RX-7 | Jeeper426 | Transmission - Rearend | 0 | 05-30-2006 07:37 PM |
| my mazda | mazdab3800 | Introduce Yourself | 2 | 05-13-2006 05:39 PM |
