96 MonteCarlo No brake lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2003, 09:08 AM
My youngest son 17 came home from school yesterday with a R&R ticket for no brake lights - the center brake light works so he never suspected a problem (he can see this light in his rear view) but the tail brake lights do not. I checked the fuses all ok replaced the stop light fuse anyway, replaces both tail light bulbs I'm sure they are ok but changed them anyway. Turn signals work Emergency flashers work, the left turn signal act a little funny blinks real fast when clicked fast into position but works fine when done nice and easy.
Old 11-07-2003, 09:48 AM
pappy 32's Avatar
Last journal entry: Heading home
brake lights
You may want to check the ground wire in the trunk. I had a 96 Impala that did the same thing. Drove me nuts. You might check the switch at the pedal it self.
With the turn signal, you may have a faulty flasher, or something at the turn signal switch.
Old 11-07-2003, 09:54 AM
Silnod's Avatar
I have had the same problems, what it can be caused by is jst flat out old age sometimes that wire loom that you have going back there is just so old that the wires start to break inside, and you wouldnt even know where the break would be. If i was you I would check under the dash and make sure that on the back of your light switch all the wires are coming out of there and look ok, and if that is fine just follow the wire loom threw the car back to the trunk if you spot anything like a split wire or a wire touching the frame, then that is your problem. If you still cant see anything and dont want to redo the whole wire loom just do this turn your light on and go to the back of the car and pull the bulb out of the back of the light holder and get a voltumeeter test the positive to see if any voltage is coming out of it, if there isnt then you have a problem in the loom or under the dash, kinda narrows it down doesnt it go ahead and climb under the dash and test the leads that are coming out of the light switch if there is nothing there then you must have have a broken wire near the fuse bodx, or a blown fuse. if there is voltage coming out of the leeds then you have a break in one of those wires in the loom, witch means you are going to have to rewire it yourself or get a premade loom .
let me know how it goes.
Old 11-07-2003, 01:41 PM
Wrencher's Avatar
If your center brake light is working, your switch is good, like pappy said check the grounds, bulbs, sockets and wires.
Old 11-12-2003, 12:05 PM
galaxieguy3's Avatar
You said that your rear turn signals work, but your brake lights do not, other than the one in the window. I would would say you have a problem with your turn signal switch. Brake lights to each individual side go through the T.S. switch.
This would apply to "all red" taillamps which use the same bulb for brake and turn signals, but I am not sure about those with seperate amber turn signals.
Skidmark
