-   -   96 S10 clutch system- air -bleeding? (http://www.hotrodders.com/forum/96-s10-clutch-system-air-bleeding-174819.html)
31chevy 03-19-2010 08:15 PM
Im I made my clutch pedal assembly for my 32 chevy using s10 parts that were brand new. At one point the system worked great from what i remember but now i feel like i have air in the system. I think this because i have to pump the clutch twice as if to compress what ever air is in there. Im not familiar with the s10 clutch system. I know its all plastic but i can seem to fin a bleed screw on the slave. What should i do.
slave lies below the master
Bryan59EC 03-19-2010 10:08 PM
If your master sticks straight out from the firewall, jacking up the rear of the car will help a lot.
I have a hydraulic system from an 86 & 88 Chev 1/2 ton
Had the same problem in the 59-----
Getting ready to remove the master and when I tilted the front down to pull it out----a bunch of air had come up thru it to the resevoir.
(88 master with a remote resevoir)
Did not even crack a line and it has been just fine ever since.
big gear head 03-20-2010 08:04 PM
Do a search or post your question here and you will probably get some good answers. http://www.s10forum.com/forum/transmission-and-rearend/
My old '84 S10 has an aluminum cylinder with a bleeder on it.
