96 S10 clutch system- air -bleeding? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2010, 07:15 PM
need strog32 chevy front doors
Last journal entry: LittleFloor
Im I made my clutch pedal assembly for my 32 chevy using s10 parts that were brand new. At one point the system worked great from what i remember but now i feel like i have air in the system. I think this because i have to pump the clutch twice as if to compress what ever air is in there. Im not familiar with the s10 clutch system. I know its all plastic but i can seem to fin a bleed screw on the slave. What should i do.
slave lies below the master
Old 03-19-2010, 09:08 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
If your master sticks straight out from the firewall, jacking up the rear of the car will help a lot.
I have a hydraulic system from an 86 & 88 Chev 1/2 ton
Had the same problem in the 59-----
Getting ready to remove the master and when I tilted the front down to pull it out----a bunch of air had come up thru it to the resevoir.
(88 master with a remote resevoir)
Did not even crack a line and it has been just fine ever since.
Old 03-20-2010, 07:04 PM
big gear head's Avatar
High Performance Rear Ends
Do a search or post your question here and you will probably get some good answers. http://www.s10forum.com/forum/transmission-and-rearend/
My old '84 S10 has an aluminum cylinder with a bleeder on it.
How do I get air out of the heater core, which is the highest point in my system?? artillerystevens Engine 5 01-12-2010 04:05 PM
S10 Air conditioner upgrade Stonebrier 2 General Rodding Tech 27 08-09-2009 05:57 PM
bleeding new brake system dar130 Suspension - Brakes - Steering 5 04-28-2008 10:48 PM
Trans Am Air System Guitarman General Rodding Tech 1 04-26-2003 09:04 PM
Air into the cooling system. TVR383 Engine 7 04-11-2003 02:54 PM
