#1
95 S10 Diff.
I'm wanting to slip a different rear end in my 95 s10 and was wondering if anyone know, off hand, what will fit. I have heard that the third gen camaros and some older 70s Novas, but i'm not sure. Any ideas??
Thanx. Last edited by Greg T : 07-21-2007 at 07:38 AM. |
| Sponsored Links |
Register now (free) or login to remove ads |
#4
s10 blazer of any year will work, but a late model will have rear disc brakes. try to find one from a 2wd because 4wd are a little wider but will still work. extreme s10s mostly had a posi unit and rear disc brake. |
#6
Make sure you use a 2 wheel drive axle. The 4x4's are wider. FYI, the Isuzu Hombre's 94 ish and newer fit too. I have a 96 isuzu under my 92 Sonoma.
ALso, the TRAILBLAZER's 2002 and newer do not bolt across. |
#7
4x4 s10 axle will fit and work but the wheels will be out farther. |
#8
98 and up blazer is what you are lookin for, they also have a stronger 28 spline axle rather than a 26(i think your 95 might already have a 28 spline becuase it is a 7.625) i am not sure but the blazers axle fits right under your truck.
#9
I'll have to do some pricing. Right now the gears are ridiculous. Gotta be about 3.90 or so and open diff. Is it possible to get a limited slip carrier to slide into that housing? Sorry for all the questions, but in all of my 35 years of building and tuning engines I have never really done much with diffs. What I would really like is a 3.23 or so limited slip. would a carrier like this fit my housing?
#10
Yes, there are gears and different style of posi carriers readily available.
Check www.jegs.com and www.summitracing.com for pricing and selection. Jegs has a house brand of gears and my 4:10's from them in my 92 Sonoma are just fine. |
#11
i think all models 88 and up are 28 spline |
#14
You don't want to use a truck diff. It isn't a "posi" (limited slip) but a Gov-Lock locker. They work like an open diff till one tire spins about 100RPM faster then the other. They then lock solid like a locker. They are known for being very weak (giving the nickname of Gov-Bomb). They aren't anything you would want in a performance vehicle. You need to look for a 28-spline diff. Stuff older then ~'89 won't work because it will be 26-spline. 3rd gen F-bodies had Torsen differentials in them and they are a good street diff. Your other options are all aftermarket.
#15
Okay, will the 3rd gen F body bolt in, or need some surgery? |
| Thread Tools | Search this Thread |
| Similar Threads for: "96 S10 Diff." | ||||
| S10 to '49 Olds? | grouch | Suspension - Brakes - Steering | 100 | 10-22-2010 04:57 PM |
| 96 s10 wiring diagram | need4speed2345 | Electrical | 0 | 04-12-2004 11:46 PM |
| '96 s10 belches ATF out the breather | BT74 | Transmission - Rearend | 1 | 12-20-2003 09:57 AM |
| 96 chevy s10 blazer turboed quick | jesshwarren | Engine | 2 | 11-28-2003 04:15 PM |
| Painting plastic trim on 96 S10 | 77chevy400 | Interior | 1 | 09-05-2003 05:59 AM |
