96 s10 transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2010, 09:49 PM
96 s10 transmission
hi , i have a problem with my 4x4 96 s10, i was driving on the highway and just change like the neutral and everything works but not run , so samebody know what is the problem if need change the transmission or just fix samething?
Old 05-21-2010, 02:06 AM
327NUT's Avatar
You need to re-word your question, hard to figure out what you are stating and or asking. I 'll take a stab...you're driving down the road and the trans just stopped engaging the engine like it's in neutral all the time? Is the clutch worn out or burned up? If this is the case then yes, you need to have a knowledgeable person take a look at it.
Drive shaft length for 96 s10 v8 swap eric32 Transmission - Rearend 5 07-07-2009 03:03 PM
Hooking up a 350 turbo speedometer cable to 96 s10 eric32 Transmission - Rearend 6 06-14-2009 05:58 PM
transmission oil type. TVR383 Transmission - Rearend 3 06-05-2005 09:28 AM
96 s10 wiring diagram need4speed2345 Electrical 0 04-12-2004 10:46 PM
'96 s10 belches ATF out the breather BT74 Transmission - Rearend 1 12-20-2003 08:57 AM
