'96 vortec 454 push rod broken after head job - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2006, 04:00 PM
We have broken about 7 intake push rods, while idleing after installing rebuilt heads. The dealer shows no service bulletins. Any ideas?
Lynn
Old 10-21-2006, 04:51 PM
NorthStar's Avatar
How close are the springs to coil bind at max lift? Also retainers may be hitting tops of guides.
I saw this happen once with Rhodes lifters, engine would idle all day long soon as it was revved up cam key would shear off. Not a bent pushrod but maybe pushrods are the "fuse" this time.
Are you using the correct lifter and pushrod combination?
Seems to me the Vortec big blocks use different lifter & different pushrod length than the earlier gen 4 big blocks.
Old 10-22-2006, 09:36 PM
454 broken push rod
Greg, I'll ck with machine shop. He might not realize this is a vortec, or there is a difference. Thanks for the tip. I'll let you know how it goes.
Lynn
Old 10-22-2006, 09:46 PM
BOBCRMAN@aol.com's Avatar
Also check valve stem to guide clearance. Too tight will stick valve and bend pushrods. BBC's need a little extra clearance.. Been there.
Old 10-22-2006, 10:50 PM
Dhevy 454 broken push rods.
Thanks, the machine shop assembled the heads and they installed a "bearing" as they call it below the spring. Perhaps this has something to do with it. I'll check back with them. Will update the site when I know.
Thanks again.
lm
stroke to rod ratio jacobm99 Engine 28 12-16-2013 06:46 PM
Looking at the remote mount turbo will my vortec heads get the job done leemoses Engine 14 10-06-2010 07:51 AM
push rod prices chevypunk Engine 6 04-18-2003 04:55 PM
bent push rod el Engine 2 03-13-2003 07:11 PM
Chipped exhaust push rod tip jpd37 Engine 4 02-21-2003 02:03 PM
