96 vortec surging problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2012, 09:12 AM
Coppertop's Avatar
I've had this intermitent surging problem with my 96 Chevy. It has a vortec in it. I would be driving down the road and it would start to cut out and hesitate. If I pull over and let it run that way for a few minutes it would eventually run properly and I would continue on. It sometimes does it at start up as well. Through experience I've just learned to let it go through this little problem simply because I have changed every sensor in the truck. I've changed the fuel pump and even used electrical grease on every connector under the hood. All 4 o2 sensors have been swapped out and at this point I'm at a loss as to WTF the problem is. Seriously cosidering a death flash and simply putting a carb on it. Anyone out there have the same issue?
Foot to the floor,hair back,knuckles white!
Old 08-11-2012, 01:47 PM
LATECH's Avatar
Maybe a vacuum leak, between the intake and upper half (plenum) .
Have you scanned it? What are the fuel trims doing?
Live data should help lead you to a trouble area.
Fact is stranger than Fiction
Old 08-11-2012, 02:23 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Have you checked your grounds, battery cables for tightness and corrosion?
Old 08-12-2012, 04:44 PM
Coppertop's Avatar
Ya,checked everything. With the exception of the **** poppet injectors. And wouldn't ya know it,that's the problem. Just gonna swap it out for the replacement set up that has electronic injectors. Thanks guys.
96 chevy, fuel injection, surging, vortec
Vortec Engine Problem DougA Engine 2 08-03-2009 12:43 AM
Vortec problem 90GMCVortec Engine 1 05-30-2008 10:39 PM
Vortec problem 90GMCVortec Engine 4 05-30-2008 12:44 PM
Engine Surging Problem Nova Does Go Engine 5 09-25-2004 08:21 AM
vortec 96 problem belgiumastro Electrical 7 04-17-2004 07:00 AM
