96 Yukon won't move... - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2007, 08:19 PM
Hi I am new so dont get annoyed if I make a mistake! I recently purchased a 96 yukon that has a new gm crate engine, problem is it don't move. The trans (700r4) & transfer case were supposed to have been rebuilt less than 1 year ago. When you put it in gear, it does not even make a noise. I was told that the transfer case may be stuck in between gears by the elecctric motor. What should I check first? ANY HELP?
Thanks
Russ
Old 11-20-2007, 08:55 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks
Russ
The trans is not a 700r4. It is a 4L60E trans .
IF the shifter motor on the t-case is bad, usually this will set a DTC and the check engine light is 'on'... I've never seen one of these t-case motors stick / stop with the t-case in neutral
Has the vehicle computer be scanned with a quality scanner , not a cheap code reader device.
You can remove the motor and try to move the t-case into a different gear position.
Old 11-21-2007, 09:51 PM
sbchevfreak's Avatar
Licenced Automotive Technician
Also, if the T-case is stuck in between ranges, or in neutral, and you put the trans in gear, then into park ( with the engine running) the park pawl wil ratchet like crazy, sounds like gears grinding. This is assumung the trans is engaging in gear.
Old 11-22-2007, 11:03 AM
put truck in park, release parking brake, try to push truck, if it rolls, t-case is most likely in neutral, or between gears.
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 08:10 PM
"Bowed" deck lid cruzinTLT Body - Exterior 3 03-04-2005 10:24 PM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 10:20 AM
Door Alignment Ron M Body - Exterior 2 08-21-2004 02:43 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 07:50 PM
