'97 5.2 new plug wires, new fuel pump, no codes? - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
View Poll Results: what is wrong?
Fuel pressure regulator 0 0%
Unknown ignition problem 1 100.00%
MAS, TPS, computer 0 0%
time for an overhaul at 125,000 miles 0 0%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Old 12-31-2011, 11:45 PM
lcash_70's Avatar
i own a 1997 5.2 liter ram 1500 4x4, about a week ago or so i had a coil plug wire fail, no problem have a new set it the tool box on board, no fix! change all plug wires and double checked firing order, timing is good, hitting on # near TDC, no fix. No codes, new fuel pump, maybe bad gas, drain, refill with new reg unleaded, purge fuel system to fuel rail, No fix, WTFish, what angle do i pursue, fuel, ignition, valve train, what? any new thought would be greatly appreciated, Happy New Year!
Old 01-01-2012, 05:35 AM
DoubleVision's Avatar
Your chasing the problem instead of fixing it and when one does this it tends to get expensive fast. All youve said it did was there was a plug wire that failed. How do you know it was the wire if the wire wasnt broken? If it still has the same problem it did from the start then that could mean Either the problem wasn't there to start with or a new wire didn't fix it. For starters do a spark test on that wire and see if its sparking. If the ignition checks out okay then check it good for vacuum leaks. Check on the bottom side of each hose for splits as this is how they hide. If they check okay then next check the MAF sensor. Take a small light screw driver, and use the handle to lightly tap the MAF sensor. If the truck coughs and goes dead the MAF needs replaced. However I should have asked first, what exactly is the truck doing?
Old 01-01-2012, 08:57 AM
LATECH's Avatar
You have said nothing about what the symptoms are.You stated a coil wire failed but obviously that was a seperate symptom? or did you just hope that was the problem and in fact fixed NADA.
Need more info, please describe symptoms as best you can.
Those are noted for ignition coil failure.
Recent Modern Electronic Engines posts with photos
Plug wires atlantis Electrical 10 06-25-2011 08:15 PM
plug wires diamond mike Engine 1 11-18-2009 08:57 AM
plug wires delsman Engine 9 04-22-2006 05:57 PM
fuel pump wires repomansaints Electrical 2 03-08-2005 08:50 PM
plug wires DoubleVision Electrical 6 03-19-2004 12:34 AM
