97 Blazer rear axle troubleshoot Automatic Level Control - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2010, 09:13 AM
Dear Rodders,
I have automatic level control on my car and would like to know
how does that system works.
I have an air pump hidden in the fender, air shocks, and a
automatic level control sensor
I disassembled the pump and tested it. I works fine.
I tested the supply of the pumps. 12V available.
I tested the pump relay. Works fine as well.
How do I test the automatic level control sensor?
Thank you in advance.
I have am 1997 Blazer Export Model.
They added the level control to pass legal requirements. They donīt want to
light up the sky if you are driving at night loaded.
BR
Bob
File Type: pdf Automatic Level Control Sensor Adjustment.pdf (12.1 KB, 101 views)
File Type: pdf Automatic Level Control Connector End Views.pdf (20.1 KB, 40 views)
Automatic level control on late '60 Cadillacs Nightrider Suspension - Brakes - Steering 0 04-19-2007 05:14 PM
72' Satellite rear axle swap bdynodave Transmission - Rearend 1 10-29-2003 11:55 PM
Jag Rear Axle -- almost completed! farna Transmission - Rearend 5 02-28-2003 07:55 AM
67ssdiagram showing how the rear sway bar and control arms connect to frame and rear DeathByGreaser Transmission - Rearend 0 02-08-2003 08:10 PM
Rear End - 5 bolt axle shafts into 6 bolt rear axle??? Blue Chevy Transmission - Rearend 0 06-07-2002 05:23 PM
