97 Camaro no start problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2005, 08:29 AM
302 Z28's Avatar
Got a buddy who has a no start problem with his 97 Camaro V6. We have traced it using GM wiring diagrams to the theft deterrent relay as the likely culprit. Problem is the manuls do not give a location for this sucker. We have been all over, under and inside the car looking for it. Anybody got any ideas as to a location?
Thanks
Vince
Old 10-20-2005, 10:38 AM
ZipZ28's Avatar
Nitrous Junkie
Last journal entry: Reflooring The Bed Pt. 2
On the 94-95's it's to the right of the glove box,,
Old 10-20-2005, 11:28 AM
302 Z28's Avatar
Thanks, will look this evening.
Vince
Old 10-20-2005, 04:48 PM
ZipZ28's Avatar
Nitrous Junkie
Here's a link that may help, it has pics of component locations on it. I had to get home from work to get to this bookmark or I'd posted it up earlier. Hope it helps!
4th Gen LT1 F-Body Technical Aids
Edited to add: I went back through that site and didn't see it but found another pic of the location.
Relay Location
Old 10-20-2005, 05:26 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
Is the security light flashing? If it is I dought you have a relay problem. It will most likely be the VATS passkey system. Those little wires going down the steering column tend to break at the lock cyl. If the system doesn't see a pre set resistance from the key pellet, the system will disable the starter ckt. There are 14 different resistance values it can be. At the shop I most of the time will just measure the key resistance and put a few resistors together to match the key pellet,and install the resister at the base of the column (small 2 wire orange harness). That way the security system "sees" a key. and allows atarter to function. Good luck!
Old 10-21-2005, 08:14 AM
302 Z28's Avatar
Security stsyem is operating properly
Thanks ZipZ28 for the information, that may be a big help.
Vince
Old 10-29-2005, 09:12 AM
302 Z28's Avatar
Thanks, it is fixed
Wish to thank everyone for the tips on the Camaro, it turned out to be an ignition switch. I was offering advice on this repair to a co-worker who lives some distance from me, so I was unable to assist other than passing on information from this site.
Thanks
Vince
Old 10-29-2005, 05:35 PM
Bowtie or Die!
[QUOTE=302/Z28]Security stsyem is operating properly
Guess I was right after all!
Old 10-29-2005, 06:25 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Thanks for posting back with the fix It may help out the next guy!
And 67 Deuce...Good Call!
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 10-30-2005, 06:30 AM
302 Z28's Avatar
[QUOTE=67 Deuce 4 Me]
Actually it wasn't the pass key system, but the start contactor on the ignition switch which was fried.
Vince
Paint problem on 97 GMC racer7201 Body - Exterior 9 06-23-2009 11:14 PM
86 Camaro 350 Charging Problem BuickGuy Electrical 1 06-14-2004 07:05 PM
90 Camaro RS Electrical Problem JulianSerna Electrical 8 05-19-2004 02:32 PM
Start up problem Dreadlord Engine 7 04-18-2004 06:59 PM
camaro just wont start ironmanc3 Engine 2 09-11-2003 04:24 PM
