'97 Camaro tacometer anomaly - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2010, 10:27 PM
Turbo-CBX's Avatar
Ugly, Filthy, Discusting!
I wired a 1997 Camaro instrument cluster to a '70 GMC powered by a 454 with typical Delco HEI distributor. The Tac gets its signal from the standard HEI Tac signal lead. The Tac works fine until it hits 3,000 rpm. With the engine still accelerating, the Tac stalls momentarily at 3,000 followed immediately by it dipping to around 1000-1500 rpm. Once the actual rpm drops below 3,000, the Tac needle comes back up and works fine until I again hit the 3,000 wall.
Is the Delco distributor (coil mounted on the distributor) Tac signal power pulse overdriving the tacometer? All connections are solid so I've already looked at a loose connection. Anyone else experienced the same problem?
Thanks
Old 01-16-2010, 01:08 AM
sqzbox's Avatar
My pipes are my music
I had the same problem with my aftermarket tach when a hot wire shorted across the wire to the dist. from the tach melting into the wire and grounding it out killing the engine. Ain't been right since.
Sounds like yours has an internal problem.
Old 01-16-2010, 05:38 AM
Jake_Dragon's Avatar
Last journal entry: New Carb
Sounds like you lost one of the coils inside the tach
It uses coils to swing the arm by pulling on a magnet. Coil gets destroyed and the tach quits working.
You will probably have to replace the tach.
Old 01-16-2010, 09:02 AM
Turbo-CBX's Avatar
Appreciate the feedback/troubleshooting ideas
Appreciate the quick responses. They give me a direction to look at. Guess the tac anomaly is what I get for buying the used cluster on-line--guess the old phrase still applies, "you get what you pay for"
Old 01-16-2010, 11:06 AM
I wonder if you could have it fixed
A quick search found
http://www.modulemaster.com/en/servi...build_info.php
Description: This rebuild is for a 1999 Camaro but covers all years with similar looking clusters. Restores full functionality of gauges and lamps.
Vehicle: Chevy Camaro
Price: $85
Old 01-16-2010, 12:12 PM
Turbo-CBX's Avatar
Good Idea--thanks!
The cluster cost me a total of $25 as an EBay purchase so the cost-benefit is a definite factor. I really like the way the gauges look (I'll upload a photo) so the desire to have it repaired is a consideration. Thanks for the website!
Old 01-16-2010, 11:28 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I believe they have hi rpm and low rpm modes.
The tach in my 79 Chev C-10 (factory) will not read below 1200 once that point has been reached.
if I start the truck and am able to start and keep it at idle or under 1000 it will read okay. But once I get going, it will not read below 1200 until I shut the truck off and restart it.
Higher RPM reads just fine
Old 01-17-2010, 08:09 AM
Turbo-CBX's Avatar
I guess our newer gm gauges are not made in Japan
Sorry to learn you have similar problems with your TAC. Maybe that's why there are so many inexpensive used instrument clusters available on-line...
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 07:35 PM
Camaro projects for sale... Zartan General Rodding Tech 30 12-12-2008 11:01 AM
95 Camaro engine swap torqjunki Introduce Yourself 1 12-18-2004 11:45 AM
Yep! I'm new 2.... Pro-Touring a '67 Camaro L8model Introduce Yourself 6 12-09-2004 12:30 PM
78 camaro to t top 87 monte carlo help isleofwight Engine 3 06-28-2004 09:29 PM
