97 camaro volt problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2010, 04:57 PM
McSS86's Avatar
my camaro seem to be givin me problem wen i put the a/c on the volt seem to drop. wen i accelerate it rises and wen i brake it drops and makes a squeakin sound plz help.
Old 02-02-2010, 05:35 PM
T-bucket23's Avatar
Wiki Edits: 26
Sounds like your alternator belt may be slipping.
You should spell check your messages before posting. It will get you more responses
Chet
Old 02-02-2010, 05:46 PM
The clutch uses current to engage. It could be the cause of the problem. You should check all connections fist. Check for chafes if ground in wire also.
But the alternator could be starting to go. The alternator will put out more current at higher rpm to over come the large draw. And on the outside chance the battery is on its last leg.
Old 02-02-2010, 06:20 PM
pops68
Last journal entry: reserected
volt prob
is this car stock ? sometimes under drive pullys will cause this prob
ABS module problem on a 97 F150 4x4 jmhollis Suspension - Brakes - Steering 1 09-03-2005 09:53 PM
97 camaro ss troy d General Rodding Tech 1 08-29-2005 04:42 PM
'97 Chrysler Town and Country (a van) electrical (?) problem. Charles F. Smith General Rodding Tech 5 03-12-2005 05:40 PM
loose T-top lock for 97 Camaro chevyelc81 Body - Exterior 0 03-03-2005 08:35 PM
69' camaro master cly. problem josh7681 Suspension - Brakes - Steering 3 12-31-2002 04:40 AM
