97 caravan - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2006, 07:18 PM
97 caravan
I'm working on a 97 caravan with 3.3 engine. The trans was rebuilt within the last 6 months. It had a wiring problem(someone installed an alarm system was backfeeding thru the light switch) I disconnected the alarm. It shifts hard and at high RPM(4000) then feels like it stays in second. I got several codes TCI-PO700,PO734,PO733. Thoughts?
Old 06-12-2006, 06:52 AM
tnsmith10's Avatar
when will it rain???
the 1st code is a generic trans fault code, the 733 and 734 codes r gear ratio error codes.
even though i dont think its related to the alarm, it may be possible., its time to take it to a trans shop and have them properly diagnose the problem.
Old 06-12-2006, 07:29 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Have you tried disconnecting the battery for 15 seconds? It may be in limp in/ default mode. Try this first and retry.
Steve
Old 06-12-2006, 09:33 AM
97 caravan
I have code reader on my laptop, and I can clean codes. But it returns to the problem after I clean them. It is in limp mode. I think its the solenoid pack.
97 350 vortec install into 1981 chevy 4x4 gnrlewis Engine 1 10-27-2005 09:17 PM
engine swap 89 350 -- 97 454 jvancity General Rodding Tech 3 02-22-2005 06:04 AM
97 Firebird Speedometer issues jimsco70 General Rodding Tech 6 12-07-2004 10:15 AM
97 k1500 4l60e huntingonedown Transmission - Rearend 1 11-21-2004 03:17 PM
97 Chevy Vortech on propane?? scheetz93 Engine 5 06-09-2004 07:25 PM
