97 chevy silverado k1500
i have a 97 chevy last week i was driving it stoped at a stop sign and when i pulled out it had a hard shift from first to second and the engine light came on. i took it to advance auto and had it checked and they said p1870 manufacture transmisson control. they told me to change my fluid and filter i did and put a bottle of lucas in it so far so good knock on wood. has any one on here run into this problem?
the mere fact that after the trans was serviced and its not throwing a code doesnt mean a whole lot,new fluid has fresh detergents, and the viscosity is thicker compared to old used fluid. its going to throw the code again, its just a matter of time. |
That code is normally associated with TCC/TorqueConverterClutch slippage. TCC Solenoid could be bad but, TCC is probably shot or TCC Regulator Valve could be leaking also. >> http://www.sonnax.com/announcements/77754-03K.pdf also TCC Apply Valve in Pump could be leaking >> http://www.sonnax.com/announcements/77805-K.pdf this is for Non-PWM TCC, 77805E-K is for PWM/PulseWidthModulated TCClutch.
"tnsmith10" is correct with that many miles it's probably ready for a complete rebuild. just plain worn out.
generally the p1870 code isa result of worn out valve body bore in the PWM system. A TransGo kit in orange box of the 4L60E JR shift kit will fix this code problem.
The code can also be related to worn out bushings and input shaft leakage - cross leaks in the stator support area. Common on higher mileage vehicles
At the Bonneville Salt Flats, first gear is known as 130 mph. |
GL
| 400 chevy short block with 97 vortec heads????? | jkelly334 | Engine | 9 | 08-13-2010 01:57 PM |
| 1983 chevy silverado MAJOR transmission problem ? | 83SILVRADO | Transmission - Rearend | 8 | 08-12-2009 06:49 PM |
| 1999 chevy silverado | 79chevy4x4 | Engine | 6 | 03-19-2007 06:17 PM |
| 97 k1500 4l60e | huntingonedown | Transmission - Rearend | 1 | 11-21-2004 03:17 PM |
| 1999 Chevy Silverado Transfer Case/Transmission? | officialfoxracer21 | Transmission - Rearend | 2 | 12-15-2002 04:56 PM |
