97 Dodge Dakota - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2005, 09:59 AM
97 Dodge Dakota
I have a 97 Dodge Dakota with a .318 V-8. Automatic transmission with overdrive switch on the shifter. When it get's hot it makes a rattling sound from the transmission and acts like the transmission is bad. Lot's of RPM's but nothing happening. If I let it cool down, it will work for a few minutes. The noise sounds like metal rattling in a tin bucket and is always an indication it's about to stop working again. I would appreciate any help you can give me please.
Old 05-29-2005, 08:08 AM
As one of the Moderators here......let me be the first to WELCOME YOU HERE...
I do not have a answer for you but there are some very knowledgeable people here....
Crosley ........one of the Moderators.......is a Transmission professional. Maybe he will see this and answer........
DEUCE.......
Old 05-29-2005, 01:48 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
If the tranny is rattling like a tin can...... it is not only acting like it is bad, I imagine it is.
The filter could be clogging up and the tranny stops working. After setting a while the oil will drain back some to allow the filter to flow fluid again till it clogs up again.
I would drop the pan to see what is in there
Old 05-29-2005, 07:11 PM
66 T-Bird's Avatar
~Low Budget Baby~
not that i know anything about tranny's (hah i chuckle everytime i say that word) but mine was acting bad and i changed the filter and it was fine, the filter had all kinds of crap in it (usual from sittin for like 30 years though) so i'd drop your pan and change the filter and fluid
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
Ford Econoline or Dodge A100 axle?? wheelsup64 Suspension - Brakes - Steering 2 01-26-2006 09:20 AM
question about dodge dakota trans notmrgoodwrench Transmission - Rearend 1 05-18-2005 07:06 PM
dodge dakota vin decoding notmrgoodwrench Engine 1 05-12-2005 05:17 PM
38 Dodge Humpback Panel on Dakota Chassis> sifua Body - Exterior 2 10-23-2004 02:37 PM
