97 Dodge ram 1500 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2007, 04:50 PM
97 Dodge ram 1500
I've got a tranny slippage problem and was wondering if rebuilding is the answer. It only slips in first gear and all the rest shift just fine including reverse. Any ideas?
Old 08-08-2007, 07:18 AM
Crosley's Avatar
Wiki Edits: 1659
high mileage on the trans?
engine siize ?
Old 08-08-2007, 07:30 AM
97 dodge
Does it feel like it has no power as you take off? Does it feel like it could be taking off in the wrong gear, 2nd or 3rd perhaps? Check engine light on?
If so, have someone"scan" the computer. Governor pressure problems are rampant with these vehicles.
Old 08-08-2007, 10:43 AM
Thats exactly what its doing. Whats it take to get that fixed? It has alomost 100,000 on it with a 318for a motor.
Old 08-08-2007, 12:07 PM
dodge
The computer creates governor pressure to work the shift valves.
The old way was with a governor on the output shaft.
Someone needs to scan this vehicle, enter the data stream and qualify this concern.
Usually the governor pressure sensor or the gov pressure solenoid will be the problem. Drop the pan to acess these, it does not require the valve body to be removed, although a little experience here will be a great benifit.
Old 08-08-2007, 12:59 PM
I'll get it checked, thank you guys.
Old 08-16-2007, 02:48 PM
How difficult is it to get this taken care of, and expensive? And will it hurt it to keep driving it till I can afford to ge it fixed?
Push Button Starter in 1998 Dodge Ram 1500 DodgeRam1500 Electrical 8 11-27-2006 02:12 AM
dodge ram 1500 rear end sagging ram1500 Introduce Yourself 1 08-04-2005 06:53 PM
HELP>>>97 DODGE RAM 1500 SS/T f17_viper Transmission - Rearend 3 03-20-2005 10:35 AM
Dodge SS/T Ram 1500 f17_viper Hotrodding Basics 3 03-06-2005 09:36 AM
Dodge Ram 1500 - ABS System 'cudabob Suspension - Brakes - Steering 4 10-23-2003 11:21 AM
