97' Expedition Check Engine light - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2007, 08:02 AM
whatwouldscoobydo's Avatar
My girlfriend has a 1997 Ford Expedition, v-8 with 104,000 miles. The check engine light came on and she brought it to a shop for diagnostic and tune up, which cost $600,($216 was to change spark plugs). Is that the going price? Guess I'm just use to my old wrecks. After 430 mi, the check engine light came back on. Brought it back to the shop, showed a different code than before. The shop fixed whatever and the light went on a third time. The diagnostic showed a different code again. The shop fixed this code message and the light went out for a while and came back on after a couple 100 miles. Now the check engine light is back on and the truck is idling rough and dying, once in awhile it does idle smooth but not for very long. Do you have any ideas on what is going wrong? Could it be that once a person has over 100,000 on their vehicle the computer is programmed to alert you to fixing everything in the vehicle????!!!!!
Thank for any advice!
Tom
Old 08-30-2007, 11:00 AM
redlightning's Avatar
What codes does it or did it have? It should be written on her paper work.
Old 08-30-2007, 12:55 PM
bigbadbowtie's Avatar
Bottle Fed
You can also go to autozone and they will pull the codes for free.
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
strange engine problem with check engine light brian12c Engine 2 07-29-2006 09:55 PM
that God forsaken check engine light stolen67 Transmission - Rearend 6 03-10-2006 10:01 PM
Check engine light 78 monte Engine 16 05-04-2005 10:33 AM
Check Engine Light? TonyMac Engine 4 05-28-2004 11:22 PM
