97 f-150 diff. remove the pinion gear??
hi guys, its a 97 ford f-150, im disasembling the rear end, i have the carrier and axles out and im trying to remove the pinion shaft, i revoved the companion flange and oil seal, but it doesnt want to come out, i even tried heating the inner race of the bearing to pound it out, nothing. did i do everything right or am i missing a step?? thanks alot guys...i know its not a hot rod but u've helped me out alot with my trans am, just hoping theres a ford guy out there...
Thanks alot.. |
Some times the pinion gear must be driven out (back) with a hammer and brass drift punch.... be careful, the teeth edges are sharp
At the Bonneville Salt Flats, first gear is known as 130 mph. |
the last bronco rolled off the assembly line in 1996
But if you have a 98 bronco ill buy it from you hahah
| Loose Gm Tilt Steering Wheel Moves Up And Down | fumplet | Suspension - Brakes - Steering | 10 | 05-13-2012 06:07 PM |
| 1999 Jeep Cherokee Rear Axle Seals - Help | leejoy | Transmission - Rearend | 2 | 05-15-2007 07:50 PM |
| Help Removing Pinion Gear Nut on GM 10-Bolt | leejoy | Transmission - Rearend | 13 | 11-11-2006 08:36 PM |
| Can't Remove Pinion Bearing Races - Help | leejoy | Transmission - Rearend | 8 | 11-10-2006 07:22 PM |
| Carrier bearing preload? | Sixshooter | Transmission - Rearend | 11 | 11-10-2005 11:35 AM |
