97 F150 ABS issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2010, 05:27 PM
fast68's Avatar
likes chevy trucks & boobies
97 F150 ABS issues
got a 97 F150 pickup the ABS light is on but it does not have ABS
Old 02-06-2010, 06:07 PM
MT71c-10's Avatar
too many toys,not enough money
Last wiki edit: Garage heating Last photo:
Wiki Edits: 13
I'm sure the 97 does have anti lock brakes, I think in the rear. Probably a sensor is out causing the light to go on.
Old 02-06-2010, 06:10 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Could also be low on fluid .
Cole
Old 02-06-2010, 06:22 PM
fast68's Avatar
new brakes all around., fluid good,
yellow ABS light,
not the red brake light
although the red brake light was on, but i just pulled the fuse for brake and it went out
there are no wheel sensors and no ABS unit that i can recognize anywhere, or at least not one i have ever seen one of. only the prop valve below the master cylinder.
lines runs straight to the prop valve and wheels.
there is a wide oval wiring plug with four wires, red, black yellow, and blue.
two round steel dome shaped things underside of the prop valve.
only the rear lines run through it.,
no wheel sensors anywhere, and the only sensor anywhere is in the axle pumpkin
ABS scan tool does nothing on this truck, yet it works fine on any other vehicles,.
operating error and check connection is all it will say,.
thanks again
Old 02-06-2010, 06:48 PM
MT71c-10's Avatar
Wiki Edits: 13
You put the fuse back in when you plugged the scanner in right.
Old 02-06-2010, 06:58 PM
fast68's Avatar
found out that in 97 you cant use a scan tool
have to connect two connectors underdash together and count flash code of the abs lamp
wow...
never expected that one
also found out that sensor in the rear axle pumpkin is real common to die in these.
and dirt cheap
so yeah i guess it really does have abs but only for the rear lines and ive never seen one like this before, that i can recall, hmmm
quotes:
97 abs systems use a lamp flash for codes,look under glove box for a tan and black connector,
ground the black conn end and count lamp flashes,will be easier to pinpoint problem.
Check the ABS sensor on top of the rear end. Mine did the same thing and I changed that and it fixed it
The dealer said they go out all the time. Only cost about 10 or 20 bucks and took about 5 minutes
to change. Hope this helps
Old 02-06-2010, 07:53 PM
MT71c-10's Avatar
Wiki Edits: 13
I wonder if the scanner you were using was not compatible with you truck. I know some of them only cover certain systems or years of vehicles.
Old 02-08-2010, 06:34 PM
fast68's Avatar
yeah im not sure on that at all.
apparently its not though.
replced the sensor today and reconnected the battery but still the light is on
have not read flash codes yet
hmm
thanks
again
F150 issues ALL FORD Transmission - Rearend 27 06-30-2009 04:28 PM
ABS module problem on a 97 F150 4x4 jmhollis Suspension - Brakes - Steering 1 09-03-2005 09:53 PM
97 Firebird tranny issues 97FloridaBird Transmission - Rearend 5 12-08-2004 05:32 AM
97 Firebird Speedometer issues jimsco70 General Rodding Tech 6 12-07-2004 10:15 AM
Abs codes ( 97 s-10) Demondrive Suspension - Brakes - Steering 0 04-29-2004 10:41 PM
