97 ford contour 2.0 with a cd4e automatic problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2009, 03:53 PM
My niece come to me with a weird tranny issue. It's a 97 ford contour 2.0 with a cd4e automatic trans. She says she can be driving down the road and all of a a sudden it's like you shift into neutral, doesn't matter what speed (it's done it on the highway and at in town speeds). If she releases the throttle for a little bit it usually comes back but occasionally it takes awhile, doesn't matter warm or cold. Some-days it doesn't do it other days it does it a lot. I've taken it for a test drive twice and have not been able to reproduce it and there are no codes stored in the computer. Tran fluid level is ok and had no odor the first time she brought it over but it did have a slight burnt odor this time. Anybody got any ideas, thoughts or suggestions. Thanks for any help
Old 12-06-2009, 05:05 PM
airworld2's Avatar
97 contour
this transmission will have bad forward direct drum, common trouble
make sure you have valve body upgraded with shift improver kit
have it checked by a shop before any work is to be done cost maybe more than the car is worth. 1500-2200 in most cases and if your looking for a used one you might find the same trouble.
Old 12-06-2009, 05:22 PM
Crosley's Avatar
Wiki Edits: 1659
cobra513 ...I edited the thread title ,
please provide some vehicle info in the thread title. The folks here know you need HELP when a question is posted
Old 12-06-2009, 06:42 PM
Rexnfx's Avatar
For intermittents, it usually turns out an electrical problem. Once something mechanical fails, it usually stays failed or is easily duplicated. That being said...The MPLS has a high failure rate. Thats the neutral safety switch Thats a guessnosis but its a cheap enough part to throw at it unless you can monitor and record the computer data and catch it glitch.
fastest muscle pre 1970 81elcamino Hotrodders' Lounge 86 01-19-2009 04:53 PM
'97 Sable electrical & washer pump problems Gearhead forever Electrical 9 12-03-2005 05:31 PM
Automatic floor shifter for a 76' Ford Truck appy_stables Transmission - Rearend 0 09-24-2003 03:55 PM
How do I install dual side pipes on on 97' Ford Ranger? John Rose Engine 2 01-15-2003 05:38 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
