97 ford F-150 no reverse sometimes - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2012, 06:19 PM
i have a 1997 ford F-150 sometimes i can get in it reverse works and others its nothing at all it never seems like its slipping either.... iv replaced the filter no luck still the same problem i was thinking maybe the MLPS is bad but it does not show any codes for it.... any thoughts or is it time for a new tranny dont wanna spend $80 on a part then need a transmission..
Old 02-08-2012, 06:49 PM
tnsmith10's Avatar
when will it rain???
how many miles are on the truck? does it matter if its hot or cold?
even with a bad mlps although they dont fail very often, the trans should still engage in forward gears.
Old 02-08-2012, 06:56 PM
87K.. doesn't matter like it stopped working a week ago changed the filter all was fine then tonight i went to go to walmart and it didn't work when i got their thats 22 miles didnt work when i came out. it worked at the gas station but not at the parts store and worked when i got home
Old 02-08-2012, 07:00 PM
also when i changed the filter the fluid was pretty black but no metal or anything i suspect it was the original filter as the plastic plug from the factory was still in the pan... the only reason i was thinking the switch was its only seemed to be doing it when it rains thought maybe it was getting moisture in it...
Old 02-09-2012, 07:21 AM
tnsmith10's Avatar
the easiest way to verify the mlps being bad is with a scan tool that has a live data stream. it will have the range positions in there and show what gear is selected.
usually with a bad mlps, shifting is erratic on upshifts.
i did some checking on whats applied when the trans is in drive and what could cause the problem and the 1 thing that caught my attention is the low roller clutch. up till 97 the trans had a roller type clutch that was known for failure. in 98, ford changed it to a mechanical diode type clutch to fix the problem. this usually gets updated on rebuild.
with the fluid being black as you describe, i would be more looking at a mechanical failure internally rather than an electronic problem.
i suspect the problem will only get worse if you continue try to drive it.
T-400 Reverse problems, slips & then no reverse Kidplunge Transmission - Rearend 1 03-14-2011 09:17 PM
Ford fast shift from reverse to low tsracer Transmission - Rearend 2 05-22-2010 08:10 PM
Ford C-4 w/ reverse valve body RSM Transmission - Rearend 5 12-17-2009 10:08 PM
No Reverse..ford truck 5 speed transmition MAYNARDTRUCKIN Transmission - Rearend 1 07-17-2007 08:17 PM
ford aod reverse shift snoman Transmission - Rearend 2 02-17-2004 07:38 PM
