97 gmc 1500 97 GMC 1500 Internal transmission squeak - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2008, 04:11 PM
Young Gun
hi all,
i have a 97 GMC 1500 2wd pick-up with the 4.3 vortec v6 engine in it, its got little over 218,000 kilometres on it. it squeaks when i turn left or hold the wheel slighty left, was told it could be the brakes, so they were checked and they aren't causing it, put the truck up in the air, turned the drive shaft to check the u joints and that wasn't it, while turning the drive shaft we notced the squeak was coming from the transmission. the squeak occurs when the driveshaft is turned so the wheels are turning in the forward direction, it didn't squeak when rotated in reverse. we believe it was coming from the rear of the transmission, i believe it is the 4L60E transmission, fluid is good and so is the level. no trouble codes present.
jordan
Old 06-25-2008, 05:37 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
You sure its not your power steering? I have never heard a trans. (squeak.) And why would turning effect the trans.? The diff. maybe..
Old 06-25-2008, 05:42 PM
SSedan64's Avatar
Dang Gremlins
Old 06-25-2008, 06:00 PM
Young Gun
i know the darn gremlins they just won't go away lol.... the trans was in the neutral position when check and a very audible squeak was heard. my shop teacher who is a mechanic checked the squeak by holding a screwdriver up to the case and the other end to his ear and he said the squeak was coming from inside, the transmission shifts fine so i don't think thats the problem. how does one check the power steering pump? wasn't the diff, we checked that as well, while checking that the squeak was heard and he asked if thats what i heard and i said yes, so we moved up to the tranny. is it possible that a the tranny mount is toast? or the left motor mount?
jordan
Old 06-25-2008, 06:13 PM
SSedan64's Avatar
Unhook the speedo cable & try it again.
The Following User Says Thank You to SSedan64 For This Useful Post:
Bert H (04-13-2013)
Old 06-25-2008, 06:41 PM
Young Gun
is that through the vehicle speed sensor, if so we had it out and it did the same thing.
jordan
Internal Reaction (Ring) Gear shattered in 700R4... indy_85stariones Transmission - Rearend 8 11-30-2006 06:31 PM
BB swap into '97 GMC 1500?? Dan B. Engine 1 03-07-2002 08:43 PM
