97 Tahoe 4L60E transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2010, 08:35 PM
I have a 97 Tahoe that needs the transmission replaced. Will a 4l60E transmission from a 96 Tahoe fit mine. The casing has this number on it 24202520. Should I be concerned about the electronics if this transmission would work and I would purchase it? Thanks
Old 06-06-2010, 08:50 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
in 1997 GM changed the 3-2 solenoid to a different ohm rating than a 1996 trans should have.
the solenoids are a direct swap into the vavle body ... however the the electrcal connector at the solenoid is different too
Old 06-17-2011, 10:22 PM
do u have a 96 4l60e
Another 4L60E swap question from 98 to 97 S10 Blazer cyclopsblown34 Transmission - Rearend 2 03-22-2010 03:27 PM
4l60e transmission question rodneydav123 Transmission - Rearend 6 03-08-2009 05:12 PM
4L60E 4x4 tarmon8r Transmission - Rearend 0 03-10-2006 08:47 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 07:23 PM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 04:15 PM
