Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - !970 Corvette brake problems
Old 08-01-2012, 07:18 PM
EdS EdS is offline
Vette brakes issue- still
Ok guys,
thanks for all of your input. Some didn't read what I said,but I appreciate your comments just the same.'re right it has inner and outer bleeder but the highest one should do the job....but....I'll do both.
Since the car is on one of my lifts, I'll also drop the front and have the back higher as one local mech. said out here. I tried a vacuum bleeder from my friends at Eastwood.......3 tools later I switched to a helper which pumped the brakes while I had a hose in fluid (about ten times ago)
I'm about to stand the car on its head as one racer suggested.
One racer said pull the fronts off the spindle and hold it as high as the rubber hose would allow and pumps them..well that good,but the problem is in the rear (I think)
thanks again...we've beat this horse to death.if I fix it,I'll let you know
thanks again
ed..........................Corvette forum will try
