do you have the screw in style pistons for the e-brake in the rear? if so you may have to adjust this first before you can bleed them I have ran across this same problem when you screw the pistons in on the rear to put the new pads they have a tendency to stay in that case adjust your e-brake then bleed if you have the seperated e-brake with the 4 piston caliper it is a pain too make them come around in that situation I would suggest using a pressure pod and force bleed them
Your just spinning your wheels IMHO what you need to do is un-hook the front brake lines at the M/C and plug it off and then start bleeding the right rear , what i did was opened it up and let it gravity feed and it didn't take to long to get there you can open both the rear at the same time if you want, and once you have it to both rear wheels, hook the line back up to the M/C again for the front and bleed them. JMO and if that don't work you will probably still have to plug the front brake line connection to the front brakes and go to the distribution block and check it there and get fluid to the rears. Then put the line back in the M/C for the fronts and bleed them. JMO Hope this all makes sense.
I have been there done that. but once you get it flowing to the rear the rest is a piece of cake. And also just to add i really don't think your 70 has a screw in pistons on it either should just press in IMHO. Or mine did anyway. Hope you can understand what i am saying to do if not just ask and i will try to explain it better ok.Cole
Done with the brakes on the 70
Guys,
thanks for the input......no screw in pistons....Vettes don't do it that way. I believe that I have it under control. I'm taking up too many peppople's time on this stupid brake thing. I've had vettes since my 1956 up to now and this is the first issue that I have had. I have a pile of vehicles and a dragster and pro-street and other NHRA qualified car but never had issues like this. So.....I set it on fire and went to sleep.......not really thanks again for the help |
I have a '76 with 'O' ring pistons and use DOT 5 fluid, which is a pain to bleed. The best method I found is to use 'Speed Bleeders', the ones with the check balls. Works for me!
| Recent General Rodding Tech posts with photos |
| 85' corvette brake keep going out | WakBordr7387 | Suspension - Brakes - Steering | 5 | 03-29-2006 09:56 PM |
| C4 Corvette Brake Questions | S10xGN | Suspension - Brakes - Steering | 22 | 02-09-2006 03:35 PM |
| 1976 Corvette brake problems | Palmtrees57chevy | Suspension - Brakes - Steering | 10 | 09-27-2005 03:21 AM |
| 68 corvette brake lights | wixomdave | Electrical | 3 | 06-22-2004 04:59 PM |
| corvette brake help?? | mikeweyman | Suspension - Brakes - Steering | 2 | 03-25-2003 07:28 PM |
