97'C1500 4L60e tranny problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2008, 08:25 AM
fiolater w/ bad 4L60E
97'C1500 4L60e tranny; lost reverse yesterday with slipping in drive and sounds like a belt slipping in reverse then i thought maybe its torque converter slipping,fluid smells burnt and if dark in color; could this be input housing or should I go for complete rebuild,its my first tranny rebuild. Its a 4.3L motor i use to haul wood to heat my home and I loaned to family who towed something to big for it. any how any response on my question would be taken,the check engine light came on but I havent gotten to run a code on it yet,thanks tony
Old 03-23-2008, 05:37 AM
Rebuild
Hay Its Wormy Again. Didnt See This One. Mine Was Doing The Same Thang. Thats A Hard Trans For Your First One. If You Have Any Ques Contact My Shop************************************.
Last edited by Crosley; 03-23-2008 at 07:21 AM. Reason: Advertising. Please see: commercial posting guidelines.
Old 03-23-2008, 07:23 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Wormy.... posting your shop contact info in the main forums is not allowed.
read the guide lines:
the rules
Old 03-23-2008, 07:27 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Sounds like the trans needs a proper rebuild.
This unit is not a DIY friendly trans for the first time rebuild.
I would suggest trying to find help with this trans or a trans shop.
4L60E pump problem burninrubber Transmission - Rearend 2 10-23-2007 01:01 PM
06 allison tranny problem nitrous_69stang Transmission - Rearend 5 07-29-2006 03:05 PM
700R4 Tranny Problem Jugg3rnaut Transmission - Rearend 2 08-21-2005 02:56 PM
T-350 tranny Problem..... jrm123180 Transmission - Rearend 5 10-09-2004 05:41 PM
4L60E tranny HELP huntingonedown Transmission - Rearend 2 05-09-2004 10:57 PM
