98 700r4trans diagramneeded - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2012, 05:58 AM
proud owner of 98 tahoe givento me i have problem its stuck in 4low needto get it in 2 hi todrive it can someone help have no money to take it to gm service thanks
Old 02-21-2012, 12:57 PM
T-bucket23's Avatar
Wiki Edits: 26
Most likely the shift motor on the transfer case is stuck. I have had some success removing them and cleaning them out to get them working again. If you just need to get it into 4 hi you can remove the shift motor and change turn the shaft in teh transfer case to the proper selection. Just leave the shift motor off or turn it by hand and leave it unplugged.
90% of these issues are the shift motor. I have seen a few modules go bad but they are generally bad due to the motor going bad
Chet
Old 02-26-2012, 09:28 AM
TexasT's Avatar
Did you ever wonder?
Last journal entry: A little follow up
Does your unit have a set of buttons on the dash that shift the transfer case? If so, this video might help.
http://www.youtube.com/watch?v=kldd1...0FB4C3CF96E284
700R4trans unclescrouge Transmission - Rearend 1 01-26-2012 12:40 AM
