98 astro 4l60e what swaps out? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2007, 09:50 PM
Hey fellows,
I have a 98astro and they say only the 98-99 4l60e works for it? I'm wondering if I use another year because I don't have the tools to do the rebuild or the $$ to pay for a rebuild unless its like the cost of a used tranny. I can find alot of other years but the 98-99 are tough to find. I'm just wondering which ones (4l60e) I could use and what all would have to do to get away with the swap?..The engine mounted to it is the 4.3vortec.
The tranny barely pulls forward and has virtually no reverse. The fluid is dark and smells burnt.
What is the difference to the 98-99 4l60e compared to other years?
Thank You for any and all help you can lend me...Take Care, Kris
Old 06-06-2007, 08:43 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by 3rdgenLT1
Hey fellows,
is this a AWD vehicle?
Your trans should be a 3 piece case unit...the bell housing unbolts
You will need to check the length of th e shift shaft from the tranny... there are short and long shafts. Long shaft is for the MLPS on the tranny
there are minor differences from a v-8 trans to a 4.3 v-6 trans , but the v-8 will bolt to the 4.3
EDIT;... there was a change of converters, bell housing and input shafts in 1999 - 2000 model yrs.... this would be the reason the 4.3 is limited to the 98 - 99 trans.
buying a used tranny of the electronic design is a real crap-shoot... good luck
Old 06-06-2007, 09:01 AM
Its not AWD...What could I expect to pay (approx) for a complete rebuild with me pulling and installing it afterwards?
Old 06-06-2007, 09:12 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I do not quote prices since there are many variables from shop to shop in different states....
perhaps there is an Indiana member here that can add to this.
Old 06-06-2007, 09:16 AM
ok that's cool...so let me say it like this if I were in your area and I had the tranny pulled out how much would you charge todo this job? approx?..
Non-hot rod question concerning '98 Astro TooSlow Engine 4 10-15-2005 05:08 AM
Spot weld driller Shoot out! MARTINSR Body - Exterior 5 05-30-2005 05:46 PM
98 4L60E billet servo blown68ssrs Transmission - Rearend 1 05-30-2004 04:46 PM
Olds 98 Ignition Module Problems awbazar Electrical 1 01-12-2004 06:42 AM
Hotrodders Knowledge Cluster: Front Clip Installs/Subframes/Frame Swaps Jon Suspension - Brakes - Steering 0 10-12-2003 03:56 PM
